  #21 (permalink)
Old 11-15-2008, 12:56 AM
ocjesse's Avatar
ocjesse ocjesse is offline
Last Online: 10-04-2009 12:16 PM
ocjesse is on a distinguished road.
ocjesse's Photo Albums
Default Re: Truck Done, New Pics
Originally Posted by BEAST-TUNDRA View Post
Two mounting brackets(which does not affect the operation of the airbags) to the chassis, using the existing flange nuts.
Funny thing is, I pulled out a stuck 30 ft. U-haul with my truck because I was in to much of a hurry to set up the pull using the winch. Other than that story, it has been dormant. Truck weighs 7000lbs. now, so I purchased a shackle to increase my pull weight from 9500 to 18000 lbs.
That's good to hear, this is exactly how the expedition one is connected to the frame. I was a little Leary because the flange nuts are smaller than what I experienced with other winch bumper mounts.
I got e1 to thrown in a pulley block to double my winch pull to 18000 lbs., just like you have. If you connect the winch line through the pulley and back to your OEM tow hook, the load should evenly divide between the bumper and frame, while still doubling your pull power.
When I had my ARB bumper on my 98 Land cruiser I used to max out the 9000lbs. winch all the time when high centered and mired in mud. That bumper always held up and was strong as an OX. I hope this expedition one bumper proves just as tough.
2008 CrewMax 5.7L Limited +Nav - Salsa Red
  • Nitto 35x13x20 (325/60r20) on Balistic 20x9 (+12mm) Wheels
  • 6" Fabtech / Dirt Logic Coil Overs
  • EXP1 Winch Bumper - Fab Fours Rear Bumper - 9500lb Superwinch - 8 PIAA Driving / Fog Lights - 3 KC 8" HID Rally Lights
  • TRD Dual Exhaust - TRD Brake Kit - Factory Nerf Bars
  • LazerLite Tonneau, Wilderness Rack, XM, Scanner and Broadband Antenna's. Davis Weather Station (remote anemometer up/down control), 3 Cameras, Shovel and High-Lift Mounts, 2 Bed Mounted 5gal. Jerry Cans
  • Bearcat Scanner (GPS and Remote Head), Ram Mounted Tablet PC (GPS - Google Earth, USB HUB, Broadband, and Video wired). Cobra Integrated GPS Radar, IPOD and XM Integrated
  • Assorted Recovery and Gadget Gear
