  #47 (permalink)
Old 11-17-2008, 05:14 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: DIY: Camry 2.2L 2001 VSV for EGR Replacement
You can always come to LV,NV and let me have a try at removing it.
Have you tried soaking the bolt with WD-40 or equvilant and getting a breaker bad instead of a wratchet which will give you more turning leverage. Some of those bolt are very tight and may even corrode a bit after time.
The wire socket has a tab that you squeeze and then the connector comes off, the vacuum hose should just pull off if you slightly twist it.
25 yrs with TOYOTA
