Old 11-17-2008, 07:05 PM
duffyatkinson's Avatar
duffyatkinson duffyatkinson is offline
Last Online: Today 02:35 PM
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: Another O2 Sensor Question
Originally Posted by Mike McKinney View Post
Great thread, I'll give you guys a quick description of what I've dealt with for years. When I bought my truck I had the guys at SOS Performance in Panama City, FL install a custom exhaust. They went with TRD headers, Borla cat-back, and Magnaflow cats. They said from their research that this gave the best performance. Since then I've had constant issues with MILs, most notably, 420/430 codes, which are now constant. They never could figure out the problem, nor could two other exhaust places I took it to, it boils down to the fact that the Magnaflow cats are too high-flow for the Toyota ECU.
I've constantly monitored the engine for years now with no undue problems that I can tell. I changed one of the rear sensors to no avail. I purchased a set of MIL eliminators but haven't installed them, hoping to find a better fix. I even called Magnaflow and spoke with one of their techs but he was stumped also.
I've done a ton of research but unfortunately haven't found a solution except for to replace the cats and go back to factory ones, not wanting to for cost reasons. Anybody have any input to my dilemma? I think in about six months I'm gonna have to do something since I'm in a different area now that requires emissions testing. Any help would be appreciated.
A couple of questions.
Q: Are you sure the MF cats are correct for your truck, and if so, are you sure that they're failing?
Q: How did you determine that it is a "flow" issue with the cats?
Q: Have the rear sensors been swapped out to see if they're reading right?
Q: And, are you sure that you don't have any type of exhaust leak between the headers and the cats?
2002 Tundra V8 SR5 AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 Truck & SUV | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
