Re: Rear Window Dead?
It costs you nothing more than time to remove the tab mentioned in the other posts (if it isn't in this post search on my username). It likely is nothing more than the tab or a slightly mis-aligned motor. If that fail then you already have the ECU in front of you and it is an easy swap (though not a cheap one, tough cheaper than having the dealer do it for you).
FWIW - mine is an 05 also.
