  #43 (permalink)
Old 12-02-2008, 09:31 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: Need wiring help with set of RAV4 OEM fog lights
Originally Posted by vmhRav4 View Post
Hi mustang67408,
I am new to this forum and need help with installing Fog Lights on my 2005 RAV4. I did purchase the Trendgear set on ebay and I have some questions:
1. Do I need a special Bracket to secure the lights in the fender?
2. Or the lights simply plug-in in place without any securing bracket?
3. Do I simply connect the lights to the factory existing wires harness?
4. Will the light handle turn on the fog lights on together with the headlights?
Thanks for your input.
vmh
1: not sure about the bracket, we always use the factory fog lights
2: They should be plugged into the existing wiring, you maybe have to cut the wires solder them with the aftermarket lights.
3:Yes
4: No, you need the TOYOTA Headlamp switch and relay, thias will make it plug and play.
PM sent
25 yrs with TOYOTA
