12-03-2008, 12:17 AM
Re: Titan or GM 6 lug rims fit 1Gen Tundra?
Originally Posted by Sizematters75
The Titan wheels will fit a 1st Gen Tundra. The lug pattern is the same except you need to make sure the rims have the correct size hub spacing or you will need spacers to offset the rim. This is the problem I am running into right now. I had to send mine off and have the hub spacing resized to fit my Tundra because the rims came off a Titan.
There was apparently some confused Titan owners...
Bolt Pattern - Nissan Titan Forum
Titan wheel bolt pattern - Nissan Titan Forum
These are what I saw innitally, apparently that is not the case though since there are many others that show it is a 6x139.7mm.
Nice, that means I have chrome rockstars that will fit a Titan!!! SWEET!!!
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
