  #68 (permalink)
Old 12-04-2008, 04:56 AM
dibble9012 dibble9012 is offline
Last Online: Today 06:23 PM
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Default Re: 2005 Tundra DC HID Retrofit Progress
You will see two step cutoffs, but as the diagram shows, they will overlap (so the passenger side is less noticeable than the drivers side.). The two cutoffs blend together. The post with the comment to lower the pass side is correct, I have since readjusted. I'll take another picture with them both adjusted correctly over the weekend.
Yes, you'll see once you have your lights open and see how the projectors are.
See the top rectangular part on top of the projector?
That piece lines up with the first horizontal line from the top of this picture. Since these were going in a higher vehicle, I spaced (using nylock nuts) the rectangular piece of the projector approx 1/8 inch from the reflector so the projectors were pointed down in the housing.
