Re: Sun Visor Problem
Hi,
Here is another option in fixing loose sun visor with I-link. This is what works for me.
- Remove the mirror/vanity light from the visor. It will hang by its wires.
- Locate where the shaft slides into the visor tube.
- With a box knife cut and remove the styrofoam to exposed the 3 tin tubes. The tin tubes are about one half inch long.
- Slide the visor off the shaft being careful not to break the electrical wires.
- With a plier gently squeeze the 3 exposed tin tubes.
- Slide the visor back in to the shaft. Visor need to be force back in if is too tight.
- Replace the mirror/vanity light in to the visor.
- If the visor is still loose squeeze the 3 exposed tin tubes again.
- Good luck. Hope this helps.
