Thread: High idle (HOT)
Old 12-08-2008, 11:16 AM
v6er's Avatar
v6er v6er is offline
Last Online: 10-19-2009 09:02 PM
v6er is on a distinguished road.
v6er's Photo Albums
Default Re: High idle (HOT)
have you checked for vacuum leaks yet? I'm thinking the IAC is working if it can change the idle like it is. So it must be an input causing the IAC to change as it is. You already cleaned the MAF, so that probobly isn't it. Give the engine bay a good inspection, check all the vacuum lines for possible leaks. Also, any check engine light now?
"The glass isnt half empty or half full...
its twice as tall as it needs to be"
~How an engineer views life
