Thanks for the pictures! But of course that only raised more questions
I saw you were running a block.....and regrets there? I have been debating on using a simple 1" block to get a little more height if I need it since I play in the rocks and not the sand. I've been eying up Toytec's 1" aluminum block....but I can't remember if aluminum or steel is better here.
And did you only weld that to the top portion of the frame rails or is that at all attached to the bed up there? Sorry it's just kind of difficult to tell from the pictures.
If I could pull something like this off and use the stock mounts I would be more than pleased! Thanks a lot for digging up these old picutres.....back when you still had a Toyota axle! And then I shouldn't have too hard of a time finding the proper length shocks by the looks of it since they aren't really at too much of a angle.
