Old 12-13-2008, 01:04 AM
duffyatkinson's Avatar
duffyatkinson duffyatkinson is offline
Last Online: Today 12:29 AM
duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: O2 Sensor Curiosity Question
Originally Posted by chinaloy View Post
Duffy, what i meant to say was that just because the front sensors fail, it does not mean the rear sensors will follow in so much as if one front fails, it seems that the other front follows very shortly after.
I agree. But as you mentioned below, O2 sensors ARE wear items, so units installed at the same time can be expected to fail at the same time.
As for the Bosch vs. NGk or Denso. I have not seen empirical evidence saying that Bosch is bad for Toyotas.
Didn't say bad; I said that significant anecdotal evidence indicates that the ECU in the Tundra does NOT like to work with the Bosch units. I'm not an engineer, so I can't tell you why. You decide whether you want to gamble on a German component in your Japanese vehicle.
As a matter of fact, I just replaced my spark plugs with the oem Densos and my mileage went down and my truck cranks over more before it starts. My orig plugs had 135k miles on them and the gap was huge, but the truck ran better. go figure.
If all you did was swap plugs, then something is distinctly wrong. You either have used an inappropriate plug, or your gaps are off.
It's electronics, the ECU doesn't care who made them, it just reacts to them.
You are correct. It IS electronics. And they rely on a certain set of expected behaviors that correlate to its operating rule set. When there is deviation (as may be expected with non-OEM electronics), then unsurprisingly there will be operating problems.
I have come to the fact that O2 sensors are wear items and they need to be changed periodically. I used the universals because of cost. They are easy enough to change. If I need to change them out 5000 miles earlier, then so be it, they were half the price of oems.
You are correct. They have electro-ceramic components that wear during use. But the OEM Denso and/or NTK units have an expected operating life of 100,000 miles in normal service.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 Synthetic 5W-30 | Mobil-1 Synthetic ATF | Magnefine ATF Filter 3/8" | K&N AF #33-2144
NGK Iridium IX Plugs #BKR6EIX | Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
