Re: anybody put spacers on your wheels?
Originally Posted by Dorado77
How thick are your spacers? What size are your BFG's.
Did you loose mpg, acceleration, handling or ride quality?
BTW your crewmax looks just right
Originally Posted by Rex Wayne
I don't understand ... how can a !/4" thick spacer help your truck. ?
Rex
How will the spacers help? they may help with your turning radius if you've added a taller tire and can't get them turning at full lock without hitting the frame or Control Arm. Spacers or wheel adapters are mainly for correcting improper backspacing and asthetics.
Wheel spacers won't change your mpg's, acceleration, or ride quality. Changing your tires will though.
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
