Re: Retrax
I have the retrax also. I looked at them all and went with retrax for one main reason. It can be locked open in ANY position. This means if I have a box in the bed that extends up past where the cover will go over it. I can sandwitch the item between the tailgate and the retrax and lock it into place so it dosen't move around.
Although it is not 100% water tight, (None of them are)it is very good. And honestly it is as water tight as the bed is anyway. I can go through a high preassure car wash and still not get water in the bed.
Works for me
08 Crew Max SR5 4x4 5.7
REMOVED Pro Comp 6" Stage I REMOVED
3 + 2.5 (rear 1" block + 1.5" AAL)
BFG AT KO 305/65/18
Retrax bed cover
Warn Trans4mer w/ muti- mount
4 PIAA ATP's
