Call them to be sure, but it looks like if you get the MUTH SIGNAL mirrors W/HEATER and then add the heat kit, you should be set.
NOTE - If you have nonheated factory mirrors you can install heated SignalŪ mirrors in conjunction with our H-MOD upgrade module.
Click here to see our H-MOD upgrade module page for more information and ordering instructions.
Mirrors
25 yrs with TOYOTA
