Originally Posted by jdubh
BTW, I wonder if this will mean our information centers will need reprogrammed...for it to estimate miles til empty i'm sure it has to have an idea of how big the tank is...
As I posted earlier, I had one in a Duramax and here is what I would expect. It will cost about the same as the other tanks, probably $1,000 give or take. It will protrude lower than the current tank and as much as a few inches below the current side panels. On the Duramax my fuel light came on when I had about ten gallons left. I don't remember if it had a miles to empty feature but I doubt it would work correctly with the new tank (unless you somehow can recalibrate it). Overall I was glad I had mine on the D'max as I towed alot and needed the extra fuel capacity. I will be a little hard pressed to justify that much expense with the Tundra as my towing is limited to a 22' skiff.
