Old 01-04-2009, 12:31 AM
Idahome Idahome is offline
Last Online: 01-25-2009 05:27 PM
Idahome is on a distinguished road.
Idahome's Photo Albums
Default Re: 2000 RAV 4 P0420 4 cyl Man
Originally Posted by Tundradrenalin View Post
Try some PB Blaster penetrating lube, let it sit a few hours after a good soaking, and then use a longer ratchet or a breaker bar. Since you've got 140k on them already, be prepared to break some nuts/bolts. A good source for part#'s is toyodiy.com. Has exploded diagrams for most every Toyota vehicle. Check it out!
Got 3 of the 4 cat bolts loose, I had to drill a 1/4 hole side ways in the head of the 4th one and them I put a philips screw drive shaft through the hole, put a leverage device on the screw driver handle and broke it loose . Hopefully new parts will be here this coming week and I'll get her back together and back on the road without a P0420 indication.
Thanks for the advice.
