Old 01-04-2009, 09:25 PM
Stage1 Stage1 is offline
Last Online: 01-07-2009 06:20 PM
Stage1 is on a distinguished road.
Stage1's Photo Albums
Default Re: 05 Highlander Stuck in PARK W/ABS LIGHTS ON
Originally Posted by DeWat View Post
The more I'm reading, the more I'm understanding. It looks like there is a selenoid switch that releases the gear shifter when the brake is pressed. I've also read that when it is a brake switch issue, the problem can be bypassed by doing a little handy work at the brake switch itself. Hopefully, yours is something as minor (and inexpensive) as a fuse so you can be on your way. I did some google searching on "stuck in park" and "toyota stuck in park", which led to a lot of the information that I saw, to include some good help right here at TS.
DeWat
Well, I went to see what I could do and the brake lights did not come on when applying brakes at first. A couple more times and they came on and I pulled the shifter out of park! I put it back in park and out again a few times and it worked fine but it did get stuck again and back to normal. I tried tonight and it works fine. I did notice one brake bulb out while driving behind her. I searched TS but did not find any information for a solution. If you could provide a link or two that would be great before I take it to the dealer.
