Old 01-15-2009, 02:27 PM
the_greenhorn's Avatar
the_greenhorn the_greenhorn is offline
Last Online: 10-26-2009 09:34 AM
the_greenhorn is on a distinguished road.
the_greenhorn's Photo Albums
Default Re: Advice On Travel Trailer Towing
you will just have to kind of find out for yourself - its all about driving style and what you're comfortable with. Tow/Haul mode is useful if you are towing a heavy trailer (which you are) in lots of steep grade hills because it will keep you in a lower gear for longer, which keeps the rpms up, which translates to more power while climbing - but also more rpm's translates to lower fuel economy. MPG is all about the rpm's.
If however, the path you take has little incline and is relatively flat - then there is really no need for tow/haul mode and you can keep it off. It is only a single button click away to turn it on or turn it off - so don't think that once you turn it on it HAS to be on the entire trip or vice versa.
As for sequential shift, I wrote in another post some time ago that I think it is just a little better than standard "D" mode. I was able to discern a difference on slight hills (and i do mean slight hills) that in sequential shift mode the truck was able to "stay in 6th" just a little bit better than when in "D" mode. How much of a difference in MPG? no way of knowing for sure, but my guess is almost NEGLIBLE. It was really just the piece of mind that on a small hill I could stay in gear and not have the truck pop down into 5th or 4th gear.
But like others have stated before - if you are towing 8500lb trailer, anything more than a moderate hill and your tranny will be trying to shift down into 3rd gear to maintain speed no matter what method you are using (sequential shift, "drive", cruise control on or off) and the only sure fire way to control that is with your own foot. If you get tired of using your foot - then set your cruise control and just get used to the fact that your rpm's and tranny will be winding up while climbing hills.
Once you drive 500-1000 miles with your truck - you'll figure out what works best for you.
08 CM LTD 4WD Nautical Blue w/RedRock
Debadged with TRD CAI,TRD Dual Ex,TRD RSB,TRD Shiftknob,TRD Sport Pedals,TRD Oilcap,Wade Bugshield,Lorado,Scosche iPod Integration, Anytime Fogs, Anytime DRL's & WeatherTech Mats
CBTMA - ROTY
