Originally Posted by Totex
Do you people think the same way I do about the gas tank being too small? Does any body knows if there is a safe after market option for this purpose?
Originally Posted by wells service
Since i have a shell and a raised carpet kit, i am thinking of putting the spare in the bed and mount a 20 gal in place of the spare. i will either use a low pressure pump to transfer the fuel or tap into the bottom of the stock tank and let the gas flow down. do you think 46 gal is enough?
Originally Posted by Raearls
I am also interested
Who is going to travel 500 miles none stop when gas go up it's going to take more money to fill up. Sometimes money you may not have want's the point of a few extra gallons and always hacking on the truck your going to stop sooner or later. You can go good bit of way with the 26 gallon tank I can go a little over a week on a tank of gas 50 miles a day some times more. You can get over 300 miles with the tank the truck has. I mean the truck is not a prius
you guys like the idea now cause gas is low right now but if it goes back up you guys will be crying about how much it takes to fill up. which means spending at least over a 100 dollars to fill up
