  #149 (permalink)
Old 01-19-2009, 09:45 PM
jdubh's Avatar
jdubh jdubh is offline
Last Online: Yesterday 04:36 PM
jdubh will become famous soon enough.
jdubh's Photo Albums
Default Re: Bigger gas tank.
Originally Posted by JBK23 View Post
Who is going to travel 500 miles none stop when gas go up it's going to take more money to fill up. Sometimes money you may not have want's the point of a few extra gallons and always hacking on the truck your going to stop sooner or later. You can go good bit of way with the 26 gallon tank I can go a little over a week on a tank of gas 50 miles a day some times more. You can get over 300 miles with the tank the truck has. I mean the truck is not a prius you guys like the idea now cause gas is low right now but if it goes back up you guys will be crying about how much it takes to fill up. which means spending at least over a 100 dollars to fill up
Last year I towed 3500 miles on a single trip. At 9-10mpg on a 26gal tank, realistically using 22-24 before stopping, that meant I had to stop about every 200 miles for gas. A 45 gallon tank would have extended that range to about 390 miles. On a trip of 3500 miles that meant 18 stops for gas vs 9 stops with the bigger tank. That's 9 less times standing at a pump, trying to a maneuver a 36ft TT in and out of small gas stations-which destroyed my under carriage bump stops....yeah, that's worth some money to me. More time at my destinations, less time stopping and starting.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
