Originally Posted by JBK23
Who is going to travel 500 miles none stop when gas go up it's going to take more money to fill up. Sometimes money you may not have want's the point of a few extra gallons and always hacking on the truck your going to stop sooner or later. You can go good bit of way with the 26 gallon tank I can go a little over a week on a tank of gas 50 miles a day some times more. You can get over 300 miles with the tank the truck has. I mean the truck is not a prius  you guys like the idea now cause gas is low right now but if it goes back up you guys will be crying about how much it takes to fill up. which means spending at least over a 100 dollars to fill up
You're right. No one should use the truck as a truck. We should use it like it's a Prius and only drive it to the grocery store. Have you ever heard of someone using a truck to tow?
