Re: Truck just won't start
Yes, sound like a bad ground or bad positive + contact, check grounds and check Bat. Cables + and - can have (sulfates) inside the cables, looks like a white powder, if you find to much it's better to change cables.
Check for rust bolts, where hold the Negative - cable to the chassis, transmission or body. clean surfaces or change bolts.
