  #66 (permalink)
Old 01-28-2009, 12:32 PM
05Moose's Avatar
05Moose 05Moose is offline
Last Online: 11-19-2009 04:40 PM
05Moose is on a distinguished road.
05Moose's Photo Albums
Default Re: DIY: How To: Fog Light Modification
Originally Posted by riceandpho View Post
hi guys, i need to ask, if i do this mod, will the fogs turn off when i have my highbeams on? i ask this to see if there is any other part to this like openeing up the steering wheel cover and tap some more wires together on the headlight stalk harness.
i did this mod on my 07 4runner sport , Toyota 4Runner Independent use of Fog Light Mod
did the fuse box thing and then steering wheel stalk switch thing also, and they all stay on. meaning when i leave the fogs on, it wont turn off when i high beam
The fogs will stay on when the fog light switch is turned on and the ignition is in the ON position. Headlights will no longer impact it as it will become a completely separate control. When you turn your truck off, the fogs turn off too.
I used the method of connecting to the green wire without removing the fuse box (drilled a hole through the separating wall, fed the wire thru, and then filled with silicone to seal out the elements...didn't want any possible water to work its way through the hole around my wire). Works like a charm!
"Think Outside the Box!"
'05 4x4 DC LB SR5 Tow Pkg BFG All-Terrain T/A KO, Leer Tonneau, Westin Platinum Nerf Bars, Fog and Map Light Mods, Orig. Owner 12/3/04
