  #17 (permalink)
Old 01-29-2009, 12:53 PM
silversequoia3 silversequoia3 is offline
Last Online: 02-23-2009 01:55 PM
silversequoia3 is on a distinguished road.
silversequoia3's Photo Albums
Default Re: need help replacing rear tail light assembly FOR 2003 SEQUOIA
After you remove the two screws in the back panel, the have to pull the assembly. The best way for me to describe it is, you have to move to the side of the truck and pull the assemble towards you. You cannot pull it straight back. There are two pins that allow the light cover to be secured against the back of the truck. One pin is towards the top, the other pin is towards the bottom. I used a screwdriver to GENTLY help me pop the pin inserts out.
Twist out the bulb assembly.
Pull out the bulb
Insert the new bulb
Twist back in the bulb assembly
Place the pins over the pin holes in the light cover mold on the side of the truck
Push in gently
replace screws and you are done.
need help replacing rear tail light assembly-passenger-side-fender_pin_locations.jpg   need help replacing rear tail light assembly-tailight-cover-pins-view.jpg
Last edited by silversequoia3; 01-29-2009 at 01:08 PM. Reason: attached photo of pin location in the fender
