Old 02-03-2009, 09:56 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: Rx300 O2 Sensor Problem (bank2, Sensor1)
Originally Posted by macboatmaster View Post
Hi,
Can anyone help pls, I have p1155 fault code opn my lexus rx300, 2001 model. 3ltr V6
Is the toyota 89467-48011 part number stamped on sensor body, which is a denso, the same sensor as 89467-41011.
Many sites seem to suggest that it is., both being Denso 234-9009.
The reason I am asking is that I can buy the first for £186.00 + vat, from the lexus dealer, whereas the second from the toyota dealer is only £135 + vat.
If anyone can help I would be obliged. Rock Auto in your part of the world lists the 41011 for my vehicle but with (Calif) after the part number, which Im thopught maybe just a local thing.
Pls help if you can.
thks Malcolm
89467-48011 will NOT interchange. This crosses over to a TOYOTA HIGHLANDER 2001 and nothing else.
The 41011 is for a Sienna /Camry and they are different.
The A/F internal Heater circuit is different, the length of the wire is also different.
P1155 is for BANK 2 sensor 1, It is located on the bank of cylinders closest to the radiator and it is the top sensor.
I do not recommend using the cheaper, incorrect part number sensor, it may cause more issues than it is worth.
Just my .02
25 yrs with TOYOTA
