Originally Posted by 08SalsaMax
Mustang, went out there and got hit with a splash of cold water..... How do you remove the bezel with the clear plastic cover over the cluster? I was hoping that the four screws were right there as the pic shows, but it appears they are covered. THANKS !!!!
If i remember correctly...(see pic)
remove 2 screws or plastic clips in the finish panel and then it should pop out, letting you access the 4 screws
25 yrs with TOYOTA
RENTAL VEHICLES
