Old 02-17-2009, 01:09 PM
duffyatkinson's Avatar
duffyatkinson duffyatkinson is offline
Last Online: Yesterday 05:24 PM
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: Another O2 Sensor Question
Originally Posted by suissevale View Post
Two months back I replaced the O2 sensor in bank one. I was just informed by Auto Zone that the sensor is gone again. My question, what is the downside of not replacing? I live in FL where vehicle inspections are not required.
Thanks in advance!
The Bank 1 sensors provide air-fuel mixture information to your vehicle's ECU. A failing/failed air-fuel ratio will allow the engine to drift from its stoichiometric balance point 14.7:1, overly enrichen the mixture, and ultimately will 1. burn out the rest of your sensors, and 2. damage your catalytic converters. The wrecked cats is where you get hit in the wallet.
What brand of sensor did you replace it with? Get them replaced as soon as possible. It'll cost you about $125 for both fronts and you can do the job yourself. I posted a detailed how-to on the procedure in another post here: http://www.tundrasolutions.com/forums/1197269-post2/
Good luck.
2002 Tundra V8 SR5 AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 Truck & SUV | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
