Your Vin does not apply for the VO6.
But does need a 50N relay rod:
SUBJECT: SSC 50N - STEERING RELAY ROD REPLACEMENT
CERTAIN 1989 – 1995 TRUCK 4WD, 1990 – 1995 4RUNNER 2WD AND 4WD, AND 1993 –
1998 T100 4WD VEHICLES (BOTH WITH AND WITHOUT POWER STEERING)
Toyota will initiate a Special Service Campaign to replace the Steering Relay Rod on certain 1989 –
1995 Truck 4WD, 1990 – 1995 4Runner 2WD and 4WD, and 1993 – 1998 T100 4WD vehicles (both with
and without Power Steering).
On the involved vehicles, if the steering wheel is repeatedly turned under certain conditions where high
steering effort is required, for instance, when fully turning the wheel while the vehicle is stopped, a fatigue
crack may develop in the Steering Relay Rod. In the worst case, the Steering Relay Rod may fracture,
causing a loss of vehicle steering control and thus increasing the possibility of a crash.
67 specs
If you want more info on the 67 PM me.
