Old 02-20-2009, 08:18 PM
RONE's Avatar
RONE RONE is offline
Last Online: Yesterday 06:52 PM
RONE is a splendid one to behold. RONE is a splendid one to behold.
RONE's Photo Albums
Default How To Install Rear Swaybar:
This is for the TRD rear swaybar (I assume the others are pretty similar). The directions TRD includes are excellent (probably the best I've ever received with an aftermarket part), so pretty much I'm just including labeled pictures to help you guys find your way. Here you go!
Tools needed: 22mm socket, 19mm socket, ratchet, torque wrench (up to 85 ft-lbs)
Parts needed: you'll probably have to go to a parts store and get 2 new bolts or 2 new nuts (the 2 bolts and 2 nuts they give you for connecting the rearlinks to the swaybar aren't the same thread count)
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
This is the driver's side. The endlink goes on the outside of the swaybar:
Click for full size
Be sure and take note of which side of the brake bracket the U-bolt goes on (driver's and passenger's sides are different):
Click for full size
Click for full size
Click for full size
