Old 02-20-2009, 09:18 PM
zpaul's Avatar
zpaul zpaul is offline
Last Online: Today 04:38 PM
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
Default Re: How To Install Rear Swaybar:
Originally Posted by ATEC View Post
Well I wonder if they changed Install PDF. My trd bar came with washers to install on sway bar end link Seventh picture down. Same pick as your but additional washers. Did you have any washers Left over. And I had no problem with Bolt threads . I try to get a picture posted. This weekend.
I had some leftover washers, so I added them like you said. But PDF that came with sway bar did not require it. And I had to buy 2 new bolts at ACE hardware store.
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
