Originally Posted by zpaul
I had some leftover washers, so I added them like you said.  But PDF that came with sway bar did not require it.  And I had to buy 2 new bolts at ACE hardware store.
Well it makes sence to install the two additional washers on bushings. The top bushing are closed on both sides with washers , then spacer. So i did the same two lower bushings.
But I do have to check mine for position of C Clamps. I THOUGHT it said to center bushing with center of sway bar. If so I am on inside of the drivers side bracket. Not outside. Rone did a nice write up with pics. I am going to have to check the clamp placement in morning.
