Re: DIY: Camry 2.2L 2001 VSV for EGR Replacement
Glad TS was able to assist you. I would have to say that you should check the drive belts for proper tension. They had to be removed to do the Timing belt and may not be set quite right.
25 yrs with TOYOTA
