Re: Tacoma Weight Distributing Hitch?
Describing the receiver on the Tacoma as weight distributing is not misleading. Some receivers cannot be used in WDH mode. You just need to add a weight distributing hitch to make the system work.
At 2,000 lbs, I wouldn't think you need a WDH. But most pop up trailers weigh more than 2,000 lbs, so I gotta ask if you are sure it weighs 2,000 lbs. The more important weight is the hitch weight. If it's less than 500 lbs, then I would say you have the option of not using a WDH. If you don't load a lot of stuff in the truck, I think you'll be fine without one.
Tom
