Originally Posted by CFEATH
Mustang67408, very kind of you to help out with the VIN questions. If you could help me I would greatly appreciate it. I'm looking at a '95 tomorrow to buy with the VIN JT3VN29V7S0057255 . It has 140,000 miles on it and I want to check to first of all see if it is eligible and maybe if the head gasket issue has already been addressed on this truck. Thank you for your help
This VIN does not apply to the V06 and the 50N has already been done.
Campaign Description: 50N - CERTAIN 1989 - 1995 TRUCK 4WD, 1990 - 1995 4RUNNER 2WD AND 4WD, AND 1993 - 1998 T100 (4WD VEHICLES EQUIPPED WITH POWER STEERING) STEERING RELAY ROD REPLACEMENT
Completion Status: Completed Date Serviced: 01/16/06
Dealer Name: TOYOTA OF REDLANDS
25 yrs with TOYOTA
