  #19 (permalink)
Old 03-13-2009, 09:07 PM
fasteddiefire's Avatar
fasteddiefire fasteddiefire is offline
Last Online: 07-07-2009 02:27 PM
fasteddiefire is on a distinguished road.
fasteddiefire's Photo Albums
Default Re: Common Signal Lines for the 2007 Tundra
Originally Posted by jliltd View Post
You only need worry about the K6 connector's parking brake pin (Pin 1) if you have an RSE (rear seat entertainment). That means there is a factory drop-down video monitor in the back seat area for the passengers to watch. I would assume any upgrade to Nav would not need this connection for any reason as there should be no RSE already in a non-nav vehicle. So basically you can forget about it. I just taped mine off when I did my install.
For clarification the parking brake connection is the purple wire in the following photo. Your color may vary so don't go by wire color, go by pin position in the connector. In this photo pin 1 is the one on the left. Now that you know which one it is, tie it off and forget about it.
I am looking to tap into this over head feed "K6" to wire a flip down monitor for the back seat. " basically a custom RSE." I am going to put the camera feed on SPDT switch with a dvd player in the glovebox. I am a novice but a brave one at that. Do I need to worry about the parking brake "green" wire or is what I am doing goin to do basically gonna bypass all that? Thanks for any help.
