Towing newbe with question about controller relay & trailer.
Hello all,
I have two questions and thanks in advance for any and all comments and suggestions.
I am running an 08' DC SR5 with the tow package. I would like to rent a travel trailer this summer. The local outfit rents a 2006 Coachmen Capri 272TBS, which I assume is a 27 footer.
I need to install a brake controller and have found much advise in this forum. I cannot however find if the tow package includes the much needed relay.
Can anyone advise? I would suspect since it is pre-wired for the controller it would have the relay but I just want to make sure.
The 272TBS has a hitch weight of 580lbs with a base weight of 4500lbs. I suspect by the time I carefully add cargo the 580 may increase a bit, and the total weight will of course move up.
If I am careful with my loading, would I need a WDH? What if I added airbags? Or could I do just fine without adding anything but the brake controller?
Thanks again for the help.
