Old 03-20-2009, 08:33 PM
MEvang's Avatar
MEvang MEvang is offline
Last Online: 01-28-2010 08:36 PM
MEvang is on a distinguished road. MEvang is on a distinguished road.
MEvang's Photo Albums
Default Re: turning rotors, rules of the game......
You really need to look at the pad surface. If there is cracking, if the surface seems much lighter then the rest of the pad, or if material flacks off, the pads are shot. Look for "rust jacking" between the steel backing plate and the pad material. If the pads are grooving the rotors then the material is much too aggressive and you should be looking for a different pad.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
