Originally Posted by Rex Wayne
I can not find any 5th wheel trailer that is within the specs. available on my 2008 SR5 DC.. with the tow pkg..
I can have a GCVW of 13,500 .. and the truck GVW is 6700 ...
and the door sticker says it can only load 1350 .. (people, gas, cargo, and guitars)
Does anyone know of a 5th wheel that would not push the Tundra over it's factory set limits...
(my insurance agent told me to stay within the factory limits, or I could be on my own if I were in an accident.. He said the weights and limits are now one of the first things that they look at to try and void your coverage)
I want a 5th wheel , but I want to be "legal" ...
Rex..
It sounds like to me Rex, that you have the 4.7L motor. Is that correct?
My 5.7L DC TRD has a GCWR of 16000 lbs, and GVWR is 7100 i beleive. Really, IMO the main thing you need to be concerned about is the GAWR listed in the camper section of your manual, when concerning a fifth wheel. It's wise to NOT exceed these ratings.
The GAWR of my truck is 4150 rear and 4100 front, which is 8250 total. I have a 6200lb (dry) 5th wheel trailer with actual weights being 7500 mostly loaded for camping. I have actually weighed this setup. Please see thread in this section titled ' 5th wheel actual weights ' to see more.
I am within my GAWR of the truck with this trailer, that has a 1250lb pin weight.
It is not hard to exceed the 7100lb GVWR of this truck with a 5er. But if you stay within the GAWR you will be perfectly safe.
Yes, you should be able to find a 5er that would work. But with your truck having those ratings, i don't know.
Here is mine, before i lifted the trailer.
