Originally Posted by Rex Wayne
Thank you for your response ..
Is there a way to figure out what is the weight on the rear axle..
Without actually putting the rear of the truck on a scale?
Rex
Had to go back a few pages here to find your answer.
Yes, but you need to go to a cat scale and weigh the setup. You could have someone else tow the trailer there and meet up to weigh it. They actually have 3 pads on the scales; front, drive axles, and trailer. When i weighed mine, i think i didn't pull far enough ahead.
Empty, the tundra DC is about 2600 lbs on the rear axle. So you have about 1400 lbs you could haul ( 5er or camper that is ).
I bumped the ' fifth wheel actual weights ' thread so you can read up on it. Some good info there.
