Old 03-24-2009, 09:59 PM
Rex Wayne Rex Wayne is offline
Last Online: 10-20-2009 10:05 PM
Rex Wayne is on a distinguished road.
Rex Wayne's Photo Albums
Default Re: Tundra ... can't find 5th wheel to fit..
Originally Posted by svedspx View Post
Just for comparison, I just picked up a 5th wheel a couple of weeks ago. Here are the specs after I weighed in at a Cat Scale. All the weights are with driver only.
Truck
07 RCSB with SAP and tow package deleted.
12k class 4 hitch
16k 5th wheel hitch
3/4 tank of gas
Ride rite (Firestone) air bags (15# to achieve ride height equal to stock)
Rancho 9000xl adj. shocks (#7 setting)
Trailer
05 Aljo 2605 27' 5th wheel
6440# factory Dry weight
940# factory Dry Pin weight
Full water and propane
Cat Scale weights
Ratings / Actual
Front axle truck 3900 / 2780
Rear axle truck 3950 / 3440
Gvwr truck 6600 / 6220
Gawr truck 7850 / 6220
Gcwr truck and tlr 14000 / 12260
Trailer axle 8000 / 6040
Pin weight ? / 1100
Trailer(tow rating) 8900 / 7140
It's amazing how fast the weight adds up when you're fully loaded and ready to go. After we camped for the weekend I stopped by the scales on my way home to see what the fully loaded trailer weighed. I found that since the fresh water tank was over the trailer axle and the gray and black water tanks were in front of the trailer axle, when the water transfered to the gray and black tanks it added about 150# to the pin weight. I also had a generator, bundle of fire wood, bike and BBQ box in the bed of the truck. These are maxed out weights in the camping mode. Although I've towed several travel trailers before, this is the 1st 5th wheel and what a difference. We had a storm blow through with some pretty strong cross winds and no sway at all. It was like the trailer was part of the truck.
Front axle truck 2780 (3900 rating)
Rear axle truck 3780 (3950 rating)
Gvw truck 6560 (6600 rating)
Trailer axle 6180 (8000 rating)
Pin weight 1340 (? rating)
Trailer 7480 (8900 tow rating)
Gcw 12740 (14000 rating)
I would have thought that you would have been over your GAWR of 3950..
What is "SAP" ?
Well, I do find these sort of reports encouraging..
Rex
