Old 04-06-2009, 09:52 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: Check engine light malfunction
Originally Posted by throttle100 View Post
hi
i have the same problem with my corolla 1997.But i tried with the key "on"
position.
First i turn the ignition switch to "on".After i put a jumper between te1 and e1(i'm sure to put it on the right pin of the test connector).
But the check engine lamp stay on without blinking.
Did i forgot something.
Thanks
The jumper wire will NOT work on a 97.
TE1 & E1 are for setting timing only. You're going to need a scan tool to read your codes.
25 yrs with TOYOTA
