Old 04-09-2009, 04:36 PM
jdubh's Avatar
jdubh jdubh is offline
Last Online: Today 03:32 PM
jdubh will become famous soon enough.
jdubh's Photo Albums
Default Re: 800 lbs tongue weight
Originally Posted by tomhole View Post
And you are using a WDH. That makes all the difference in the world. I just towed the camper home without the WDH engaged. Hitch weight is 750 lbs. The headlights were pointed at the sky. Dangerous way to tow for any length of time or frequency.
For the OP, if you plan to tow this load more than once, think about adding a WDH to level the load.
Tom
Of course, it says right on the hitch that if you tow anything with over 500lbs of tongue weight then you must use WDH. But even at 1000lbs tows fine for miles.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
