Old 04-09-2009, 05:06 PM
Jowett Engineering's Avatar
Jowett Engineering Jowett Engineering is online now
Preferred Dealer
Last Online: Today 11:07 PM
Jowett Engineering has much to be proud of. Jowett Engineering has much to be proud of. Jowett Engineering has much to be proud of. Jowett Engineering has much to be proud of.
Jowett Engineering's Photo Albums
Default Re: Project traction
The case has arrived. It dosn't look a whole lot different on the outside, the only noteworthy change is a large grouping of cooling fins cast into the front side and bottom of the case.
Front diff... no differential disconnect.
Inside things are quite different. The center Torsen Differential is a T3 3rd generation piece. It is rear drive axle biased and can supply up to 70% of the torque to rear wheels... that means less understeer.
Center Torsen differential, Torsen is now owned by Toyota.
Brian
Jowett Engineering
Extreme duty parts for the Tundra that works and plays.
Webpage coming soon!
2008 DC TRD Supercharged w/ AWD
