Re: DIY: How To: Fog Light Modification
Originally Posted by voltage25
I am going to do this mod by grabbing power for the foglight relay from the parking lights. (IE. instead of connecting to the light green wire in the fuse panel, connect it to the green wire for the parking lights) This will perform the following functions:
Fog lights off when foglight or headlight switch is off.
Fog lights on when foglight switch is on and the following are true:
Parking lights on, or Low beams on, or High Beams on,
If foglights are on and you forget to turn them off when key is removed they will turn off with the parking lights.
Foglights will NOT come on after 5 hours like the original mod.
Better way IMHO.
FYI, they won't come on after 5 hours when using the light green wire either.
"Think Outside the Box!"
'05 4x4 DC LB SR5 Tow Pkg BFG All-Terrain T/A KO, Leer Tonneau, Westin Platinum Nerf Bars, Fog and Map Light Mods, Orig. Owner 12/3/04
