Old 04-12-2009, 11:12 AM
WT's Avatar
WT WT is offline
Last Online: Today 01:25 PM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: can't stand it anymore!!
Get one of the PAC units it cure the problem. It just seems there a ground loop that gets created when you plug in a source into the 3.5mm AUX jack and that same source is gettign power for 12V in the truck. I used the PAC SNI-1/3.5 and it cured my problem with AUX input from my Blackberry to the the AUX port to stream digital radio to it. Cheap and quick fix. Ypu you want to test it out get a secondary power soruce to feed the input device battery or maybe ever 12V from a battery charger you see that the humm goes away when there is silence or simply pull the plug from the AUX jack no more humm cause your introducing it through the source device when plugged in.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
