Old 04-15-2009, 12:32 PM
ROKTOY829 ROKTOY829 is offline
Last Online: 06-08-2009 03:13 PM
ROKTOY829 is on a distinguished road.
ROKTOY829's Photo Albums
Default Re: 1998 Avalon front camber adjustment
Do you know if the camber is out on the front? I don't see the struts going bad in a years time under normal driving. I have seen springs go bad and cause a pull but they didn't cause a wear issue. There's a few ways to adjust the camber if it is out. 1st is to simply loosen the bolts that attach the strut to the spindle and adjust with the slack that it allows. 2nd is you can replace the bolts. They are a shoulder bolt that is desgined to adjust the camber. I would go with alignment first cause that will give you a starting point.
