Old 04-16-2009, 11:12 AM
Herbicidal's Avatar
Herbicidal Herbicidal is offline
Just a Herbicidal maniac.
Last Online: Yesterday 06:23 PM
Herbicidal's Photo Albums
Default Re: front hitch and cooling
Originally Posted by nicculi View Post
I'm thinking about installing a front mount hitch for use with a winch. I'm a bit worried about the reduction in approach angle, and cradle attachment in adverse situations. I'm thinking about building one that exits behind the front plate area, my only concern is that my cross tube, will block airflow through the bumper and thus reduce my cooling efficiency. Anyone know what kind of trouble I might get into with cooling issues?
thx
I would suspect, but can't prove, that it won't reduce cooling by all that much, if at all. The bumper opening on the 1st gen Tundra's just isn't that big. I have the Warn Trans4mer system with a non-removable winch up font (see my photo album) and I've very happy with this setup. The winch and mounting plate pretty much bocks off the bumper opening, however, six inches of lift and 35's keeps it up and out of the way of trail obstacles. In all my times out wheelin I have never had the engine temp gauge move off dead center. The ONLY time I've had the temp gauge move even a little bit was pulling our 26' Outback TT (scaled weight of 5,600 lbs) south bound on I-5 here in California up the "Grapevine". This is a very steep climb before getting to southern CA. I got stuck behind a big rig on this grade and I could not safely pull out and pass him. So I had to sit behind him for about 15 minutes doing appro. 25 mph to the top. That was a rather extreme situation, so I don't believe that blocking the bumper opening is going to cause you any concern in day to day driving out on the trails. So in my opinion - go for it!
