Originally Posted by Jason.MZW20
The only real issue that Toyota voluntarily fixes based on a consumer complaint is the rear spring issue or bottoming out with a heavy load in the truck bed. I'm not sure if the 09s are running higher rate 3-leaf springs or not, but the updated 4-leaf springs made my Tacoma's rear feel less sloppy, for sure.
AFAIK, the TSB covered Access Cab and Double Cab Tacomas up to 08. I'm not sure if they added the 09s or not.
I'm having problems with my 07 dble cab, short bed bottoming out when there is a moderate load in the bed. You're saying Toyota is voluntarily fixing that?
