Old 04-25-2009, 03:34 PM
shawnd2 shawnd2 is offline
Last Online: 11-08-2009 08:35 PM
shawnd2 is on a distinguished road.
shawnd2's Photo Albums
Default Re: What to watch out for, and mileage
Originally Posted by thunder_pkg View Post
You should also get used to the fact that the climate control system was designed for a single cab, and is woefully inadequate on the doubles.
This is most apparent if you have four people in the truck in winter (for instance, going to the rink). The climate control system is completely overwhelmed by any moisture in the cab.
Expect icing on the inside of the windows and lingering high humidity if there is any snow tracked into the cab.
The climate control system is weak, weak, weak.
There is a TSB out that may address this. It is TSB-0072-09 (decreased air volume from HVAC when set a maximum heat). It may be worth talking to the dealer about it,
Shawn
