Re: 800 lbs tongue weight
Well I talked with Equalizer today about the issue, and they suggested that I lift up the L brackets one hole at a time and see if it helps out, or I can take apart the hole assembly and add another washer which both will result in the same effect. They told me that through the different dealerships have told them that actually setting them up per the instructions was not the case and it was better to increase the amount of height above the hitch in order to give the correct amount of lift. The spring bars are not the case according to them.
